Hey folks,
I have a problem with our lane 13. The sweep motor is overheating constantly. For about 3 days it was overheating just by being turned on. It ran longer today than in the last 3 days. It will run fine for a short time than the kilxon pops. By the time I get to it the motor is extremely hot to the touch. *After another look, everytime the sweep motor runs it begins to heat up. After 10 cycles the motor was already hot.*
I have checked all the pins in the C-1 plug, Changed chassis, Changed gear boxes, Changed motors (3 times), removed shims from motor, changed capacitors 2 times, changed motor plug, cheacked for bad ground, checked the terminal strip. Both gearboxes are full with oil.
Just for joy I have changed the capscitors again, and put a different chassis on the lane.
I have Westing house motors, and SS chassis with expander set.
Any help?
Thanks
Critical
Any help?
Thanks
Critical
