Bad chassis...
  • Bad chassis...
    Got a machine that won't feel for pins after 1st ball. Wants to set full rack on standing pins. If 1st ball was a strike, it will set a new rack then sweep it off and set another one. Swapped chassis' and that is the problem, but I don't know where to attack the issue in the chassis. Is it contacts? Relays? Machines are 82-70s with one board chassis. Any tips will be appreciated.
    Re: Bad chassis...
    pot relay is bad. If changing relays doesnt help check the C1 plug at terminals35 and 36.
    Good luck. Paul
      Re: Bad chassis...
      That should read Spot relay is bad. Sorry
        Re: Bad chassis...
        Ditto that, sounds like the spotting relay to me also
          Re: Bad chassis...
          Thanks, guys. I'll check that out tonight.
            Re: Bad chassis...
            That was it. Thanks again.
