mp chassis
  • mp chassis
    i have a mp chassis that someone replaced the c2 plug on it,but i know that the wires are in the wrong spots. why they did not do one pin at a time who knows ,but they did not. does anyone have a diagram of the plug showing were the wires go? all i have is one for the solid state chassis and the numbers on the wires are diff on the mp chassis.my mp chassis are from the mid 80s.
    Re: mp chassis
    in the 82/70 manual there is a final wiring diagram for an MP chassis at the rear of the manual. This shows the position of the pins and where they go on the tag strips under the boxbeam cover etc.I am sorry i do not have access to send photo of this and hopefully someone else can. but the amf site may have the manual on it for downloading.
    Failing that meter the cables on the adjacent machine , write them down and copy it.do this from the C2a plug to the vatious tag strips , it will be time consuming and the numbers may not be the same.Hopefully someone locally can get you a copy.
    maister
      Re: mp chassis
      that will help thank you
        Re: mp chassis
        I have a cheat sheet at the full time job that I maped out myself. If you dont find what you need, let me know. You can call me tuesday at (775) 789-2282 between 2pm and 10 pm Pacific time, and I will find a way to get it to you.
