no cycle
  • no cycle
    82-70 Pinsotter mp chassis, vortec brunwick scoring, Machine cycles from chassis, but no cycle from ball detectors.
    Re: no cycle
    The manager has ruled out the ball detectors and board by the camera. So I need to know where to look for connections that the scoring uses to start machine cycle.
    Also the detector does seem to be working since if a ball is thrown and cycle using the MP Chassis it does score, so the detectors are sensing the ball but do not trigger a machine cycle.
    Any advice would be great
    thanks
      Re: no cycle
      Now I am really confused. I hooked the SS to the chassis plug which is a cycle without score just to get it to cycle when the ball hits the cushion and it only cycles if a ball is not thrown. Something in the scoring wont let it cycle from that circuit when a ball is thrown???
      Also found out the reset button on the power lift does not work.
        Re: no cycle
        The ball detectors and the failure of the button on the power lift rack are good clues that the problem lies somewhere in the A&MC box. This is usually where power lift resets and ball detectors are tied into the machine wiring. Make sure all wires connected to A&MC terminals 1&2 are properly terminated.
          Re: no cycle
          Thanks Kat I did notice that the A&MC Box is open for some reason. I will check it.
          What exactly to you mean By terminated??
            Re: no cycle
            Make sure that the cable from the AMC box is plugged into the machine completely. Sometimes they get moved when changing ball wiper cloths.
              Re: no cycle
              i dont know the scoring system, but definitely in the circuit from the ball detector to a & mc box pins 1 and 2.you could take the cables from the adjacent lane in the a & mc box and switch to the problem machine to quickly test the circuit, in other words take the wires from 1 & 2 and switch them over and throw a ball or activate the sensor to see if fault tranfers.
              good luck.
              maister
                Re: no cycle
                <font size="2" face="Verdana, Helvetica, sans-serif">Meaning all female spade conectors are properly seated to the right terminals, and that the connectors themselves are securely crimped to the wire. Those A&amp;MC boxes are a tight squeeze and with all the extra crap we've added in there over the years due to scoring, ball detects, and such wires are prone to getting knocked off terminals, wires pinched in the door, etc. Hope this steers you in the right direction.
                  Re: no cycle
                  Thanks Kat, the A&amp;MC box is quite a mess with a lot of wires hanging there not connected (just like the the whole house). That is what I thought you meant. I will be back there around noon today. Will post what I find tonight.
                  Eric
                    Re: no cycle
                    You should be able to put a jumper across 1 &amp; 2 in the A&amp;MC box to get a cycle.
                    By doing this if you have a cycle:
                    Then it’s the wires coming from the components to A&amp;MC #1 &amp; #2 (i.e….10th frame, electronic triggering or machine interface).
                    If you do not have a cycle by jumping 1 &amp; 2:
                    You have a break from the A&amp;MC box to the C2A plug. Most likely it is the plug that comes from the A&amp;MC box that plugs in the side of the wire way in-between the ball lift as Tall Paul suggests. The pins responsible for cycle in this plug are #13 &amp; #14.
                    You might need a cheater wire to test the continuity:
                    A&amp;MC #1 to C2A-32E
                    A&amp;MC #2 to C2A-31A
                    Triac
                      Re: no cycle
                      Problem Solved: There was no cycle by jumping terms 1 &amp; 2 in A&amp;MC. Started checking continuity from there to machine. Found that SA was not working properly. There is a scoring cable hanging by the sweep switch that used to be there to take out the SS switch. I believe the switch was called ASP (Automatic Scoring Protection). I think when the bruns tech was here on Friday he may have inadvertantly separated the terminals on those wires which take SA out. That is all it was. Pair of lanes down all weekend.
                      Thanks for all the advice.
                      EW
                        Re: no cycle
                        Glad you got it Eric. I forgot to mention that all cycle inputs go thru the SA NO contacts to get their ground.
                        I think the part that threw me was, that you cycled it thru the chassis. Apparently, the cycle button on the chassis has its own ground and I was not aware of this.
                        Thanks for posting the solution as this will help others with a similar problem. I even got a lesson on the cycle input for an MP chassis as further investigation shows it on the schematics bypassing the SA to get its ground.
                        Triac
                        Ball Returns Shorted Out?
                        Trip rocker arm
                        Lower ball cushion board
                        Backend motor plug
                        82/70 combi motors
