Alternate Pillow Block
Member
- Aug 1999
- 2547
- A-2s, GS-X, 82/70-90
- Brunswick Vector Plus HD
- Brunswick Envoy
- Pro-Anvil
- 1985
I was visiting a nearby center recently and saw they had a new style of pillow block bearings for the sweep and table torque tubes. They were different from the OEM sheet metal types that like to break...they were sort of a casting type which did not have the two strap setup like the OEM. Are these a Stahls Seventys deal or what? Does anyone know if there is a Grainger setup like this that would work? It's time for me to order some pillow block assy's, but would like to get hold of those cast jobbies as they look much more durable that the two-strap style that likes to break at the worst possible time. Thanks guys."Where are we going, and why are we in a hand basket?"
--KatTags: None
Re: Alternate Pillow Block
The early 70's had cast iron pillow blocks, they were not self centering and were expensive.
They were replaced by the strap type.Please.....follow the instructions!!
John
804-240-4982
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
John and Clutch,
Thanks for the insight. These pillow blocks actually look brand new whihch was why I brought up the Grainger thing. I looked thru the catalog and saw some of the cast types that had self-centering bearings. Wonder if this would work???"Where are we going, and why are we in a hand basket?"
Tech of the Year 2009
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
I've had to replace 3 in the 26 years I've been working on 70's. Inspect & grease them regular, They'll last forever.Even a old dog can bury a bone
King, if you stay working on the 30's you will see more break. I seen more than 3 break on the 30's in the 11 years I worked on them.
Frank.always doing my best.
Originally posted by 82/30 king:
I have only seen 2 or 3 strap style pillow blocks break in 20+ years.
puts too much pressure on the spot solenoid lever and it will bind and not operate.
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
Partnumber:
No, it definitely wasn't a 90s style as I have several of those throughout the house."Where are we going, and why are we in a hand basket?"
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
That's it. Thanks for the pic Wang."Where are we going, and why are we in a hand basket?"
You're welcome Kat. The link for the pic came directly from stahls site at <a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank"><a href="http://www.tuffyparts.com." target="_blank">http://www.tuffyparts.com.</a></a></a></a></a></a></a></a></a></a>
Wang
The reason the straps break on a 30 is because of machines running out of time and the sweep and table getting jammed. All this interaction is transferred to the TGT side through the spotting rod. Have never seen one break on the R.H. side of a 30's table.
A 70 or 90 seems to be a different story. With pressure being applied equal to both sides because of table and shuttle jams and tables banging off the pindeck looks like both pillow blocks are fair game.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
