scissors won't open
  • scissors won't open
    I have a lane that the scissors won't open during at the bottom of a normal cycle... it picks them up goes up, comes down, and won't open... after that, if I put it in manual and lower the table, it opens fine. HELP ME PLEASE!!!!
    Re: scissors won't open
    Check the adj of the respot rod, the finger link should be about 1/8" away from the high point of the shifter link.
    Could be the bolt on the end of the shifter cam link has backed up.
    Anyone change a respot cell recently?
    John
    804-240-4982
      You can call me if you like 804-240-4982
      John
      804-240-4982
        If you have a gap that is too tight, it will also cause this. If you eliminate the respot rod, try picking up 1 pin at a time until you find the problem cell.
          Hey, scissors are not on AMF machines!
            Pawl adjustment.
            Bent pivot stud.
              Hand crank it down to where it should release and then go down and look around for a bind or something. (Please pull the R/S plug.)
              Rep. Rob Bishop (R-UT)
                front stud bent? That throws everything off.
                  Originally posted by 82/30 king:
                  Pawl adjustment.
                  Bent pivot stud.
                  <font size="2" face="Verdana, Helvetica, sans-serif">Ummmm Thats spelt Paul.....lmao....(jk)
                    I use scissors to cut paper. Sorry, just had to say it. Like Ted said
                    Go Pirates
                      Maybe the scissors are stuck on the rake under the deck.
                        check all your pivot studs. gotta have 1 or 2 bent.
                          When the RSC’s work with no load, do they kinda snap open? After checking your Pawl adjustment and looking for bent studs…Make sure that the adjustment on the shifter cam link stop bolt is turned in 4 turns after contact.
                          Triac
                            <font size="2" face="Verdana, Helvetica, sans-serif">LMFAO! Can't find part number for "rake" on my pinsetter! HA
                              You can't find a rake, deck, or a sissor. Maybe u could locate the mouse trap, or the Christmas tree???
                              Slow down, take a second, NOWFIXIT!!!!!!
