Table hinge assembley
  • Table hinge assembley
    mmmmmmmmmmmmmmmmmmm part number anyone?
    Re: Table hinge assembley
    1/2-004-002
    Half way down isle 4 on second shelf at your local Lowes.
      Right next to the Kniffling Pins......
      Lane Concepts, Inc
      Maximum Torque Specialties, Inc
        <font size="2" face="Verdana, Helvetica, sans-serif">Ummm...I do believe that there is an AMF part # for the Kniffling Pin kind sir. [img]/content/btubb/images/%%GRAEMLIN_URL%%/rotflol.gif[/img]
          What the hell is that???
            Kenny, I do believe you'll have to explain. I'm not as astute on the equipment as you are.
            By the way, thanks for the tour, and I have to say again, your machines are in the top 1% for cleanliness. It must be because you keep up the mantainence of those damn Kniffling pins.
            Lane Concepts, Inc
              No no, got it all wrong, there is another hinge on the frame, you line the table up with it, install the kniffing pin so they can flip the table down for service.
              Gotta keep the Kniffing pins in good shape ya know.
              John
              804-240-4982
                Ok...Here's the story behind the Kniffling pin.
                I had a machine that wouldn't spot pins. I had a female pinchaser on duty that was fairly new at this time and this problem was out of her league. She goes up front to tell them that the machine would be down until I could come in and fix it...Well there were two guys up front that have worked on these before and told her that they would come look at it for her, they show her the problem and said we'll let Kenny fix it...I come in and ran the machine, after one cycle I notice the table latch didn't move...I go straight to the spot soleniod pull the cover off and notice that the link had came apart (lost X washers some how)...Anyhow my female pinchaser comes in and asked me if I got it fixed, I said yes let me show you what it was...She tells me that the other guys were showing her that the problem was in the shuttle (don't remember exactly what it was that they showed her)...The two guys come in and asked me if I got the lane fixed and I said yes...With my pinchaser at my side they asked what it was and I told them that the Kniffling pin had snapped, they both looked at each other and said to me "yeah we thought that might have been the problem" I smiled and walked away with my pinchaser...When we get away from them she says to me "that's not what you told me what it was" I again smiled and told her that I was testing their knowledge and that there was no such thing as a Kniffling pin...These two had her believing that they knew as much if not more about the machines than I did...From that day forward she never listened to them again.
                That's how the Kniffling pin was born. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                Thanks Paul...Looking forward to your next visit.
                  Great story Kenny. As for the kniffling pins, they must exist. I found the following passage from another forum while "Googling" for kniffling pins...
                  "To me it sounds like the kniffling pin is not inserted correctly into the widgit, and its low on turn signal fluid". [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                    Goes along with the muffler bearings and tire hinges.
