8290xl's
  • 8290xl's
    We have as80 scoring mixed with 79 scanners and some camaras, we are running the scorers with Purrfect Desk, we are looking into getting the xl90s. Is the scoring compatible? Is there an interface between the two or would I have to look into new scoring also. Thanks
    Re: 8290xl's
    90 XLs require a camera and ball trigger. There are no table cell wires and no cushion switch. The machine cycles based on pin count data from the camera. (Sweep reverse and quick strike).
    There is no data out from the Brunswick scoring to control the machine.
    You would have to have the AMF camera as well as the scanners for scoring to work.
    Pinspotter control would have to be with the MCU for the 90's (more serial data). Otherwise, you'd have to run the machines in 'manual' mode and use the LIU or source command box to open/close the masking unit switch. Bad idea - manual mode eliminates the machine on warning, off delay and the ball returns run all the time - have to use breakers to turn them off.
    I've put in XLs with Mendes scoring and used 2 cameras (until AMF got with the Mendes folks and worked out the data link).
      Re: 8290xl's
      We have as/80 with model 86 scanners and the 90xl upgrade on our 70's. Amf wanted to use the overlane hoop to mount the cameras over the scanners. Didnt like that setup so we went with raising the scanners and putting the camera in front of the scanner. There is a picture of this setup on bowltech somewhere. I will look for it.
      It works fine for us. Only thing we couldnt use was the 7,10 and gutterball short cycle and auto cycle in tenth frame.
        Re: 8290xl's
        See, It'll work.
        Make a deal to update the scoring so you'll have the data output to control those 'smart' machines.
        AS+ will interface and need only 1 camera, and give you the pin fall data for the cycles you want.
        Next it's new scoring. I think most offer the data flow for 70s and 90s.
        Nice hybrid, Mreessr!
        90's, 86 scanner AS-90s, AMF durabowl bumpers, Bwick Anvilane, Bwick capping.
        By the way, did you save the top of the AMF camera tower you cut off?
          Re: 8290xl's
          Amf cut all the cameras. When one went down I had to use the new boards in the cut frame.
          Btw those are Bruns. bumpers. We also have 16 lanes of the durabowl on the other end of the house. .Also B power lifts, Amf masks, And Frameworx ball racks.
          Looks like we are getting new scoring this summer,(prob. Qubica) so the camera/scanner setup will be gone.
            Re: 8290xl's
            I agree, nice mod for the camera scanner problem.
            John
            804-240-4982
              Re: 8290xl's
              Nice set up you have there. I like the blue gutters. Ours are grey.
              Save the environment, eat more beef.
              No more Ethanol, save Beer.
                Re: 8290xl's
                I've never seen Brunswick blue bumpers. But now that you corrected me, I can see under the rail - and it's blue next to the lane!
                Brunswick still market color options?
                  Re: 8290xl's
                  Try the same setup with Accucam 3000. That's what will come with the XL's.
