10 on 10
10 on 10
These are ss with expanders and table wiring removed and 12 strike scoring. I have not seen it happen but when the machine is cycled, the sweep will drop to 90 and it will immediately shuttle and spot on top of standing pins. I don't for sure if it does it from the mechanic's control box or when the ball goes thru the ball detect. I have not been there yet but will tonite. Bad ground in chassis? tac board terminal loose? cluster cams not changing logic? Please help!! BillYeah but, We've always done it that way.Tags: None
Re: 10 on 10
Does the sweep run through like a normal strike cycle?? or drop to 1st guard and table spots?? does the sweep return to 0 after it tries to spot? If the sweep does not run through the deck b4 table spots, might be solenoid firing early (sweep should then stay at guard, as it will get an oor signal) or maybe even mechanical in nature, but that would be wierd on 2 seperate lanes. Have you moved chassis then expanders to isolate problem??
Re: 10 on 10
Change the chassis to eliminate it (including board and SP relay).
Check whether the spotting linkage is stuck in the engaged position (due possibly to broken spring or a bind).
Andrew.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
