pindeck light
  • pindeck light
    hi all,i was wondering if anyone knows which board or part of the 82/90 1st gen chassis runs the pindeck light,ive got a few,which ive had to wire to the back -end motor because of the light going out all the time,
    any ideas would be much appreciated.
    many thanks,
    dave
    Re: pindeck light
    On the 70, it comes off one of the M relays... I'm going to assume there's a similar setup on the 90. Burned/arced relay contacts, maybe?
      Re: pindeck light
      MAybe this picture I just made can help you
      greetz Niels
        Re: pindeck light
        if it is the silver chassis there are fuses and relays inside on the base of the chassis.
        maister
