70xli upgrade PROBLEM
  • 70xli upgrade PROBLEM
    Im posting this on behalf of a friend; he may post shortly after this, I dont know.
    Problem is a '70 that has had the Xli upgrade done on it. I am not familiar with the electrical side of the upgrade so I thought I'd ask some of you.
    The pinsetter in question is apparently powering completely down after the table is run for awhile. He says it will run for about twenty minutes (the table) and then the pinsetter blacks out. AMF I guess has told him to change some sort of relay/trigger that counts table drive revolutions(?) in the hopes that clears it up.
    Those of you with Xli experience (Mr. Isbell) or that have them currently please throw some suggestions our way.
    Thanks in advance.
    Re: 70xli upgrade PROBLEM
    <font size="2" face="Verdana, Helvetica, sans-serif">I call shenanigans.
    The Monkey has no friends.
    Sorry, you left yourself wide open my buddy!
    [img]/content/btubb/images/%%GRAEMLIN_URL%%/rotflol.gif[/img]
      It sounds like AMF is refering to the pass through sensor. Same one as on the sanction oil machines for tach and LDS. It is how the chassis knows the position of the sweep/table, and completly replaces the 3 cams and cam switches for both.
        Originally posted by 82/30 king:
        [b] </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by *70*PinMonkey:
        [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_nworthy.gif[/img]
          <font size="2" face="Verdana, Helvetica, sans-serif">.... and if it fails, does it kill the whole pinsetter? Blackout?
            sorry....there is no XLI pins'etter'. Mashers latest is the GS series... If you are refering to the pin'SPOTTER', then yes.... any error and the chassis shuts down. If AMF suggested replacing that pass through sensor, I would definantly start there. (swap one from another lane.... maybe clean the one off the trouble lane, may nust be gunk)
            Good luck
            (Brunx just 'sets' pins down anywhere.... AMF 'spots' a nice rack)
              <font size="2" face="Verdana, Helvetica, sans-serif">Nice touch [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] ... but you're opening yourself up to a ****storm... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                Originally posted by TheGMan143:
                </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JimDorsin:
                <font size="2" face="Verdana, Helvetica, sans-serif">Nice touch [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] ... but you're opening yourself up to a ****storm... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">[img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                  Pin monkey we had a simalar thing happen when I was at Drills place it came to be a bad spotting cylinoid. Replaced it and problem went away. It would show up after about thirty minutes of running.
                    A little off topic but....
                    Does the 70 XL upgrade work with double solenoid machines?
                      Will eliminate the second. The salesman can be pushed to include the links.
                        <font size="2" face="Verdana, Helvetica, sans-serif">abloslutly!!!! more $262 for the kit....lol (its worth it)
                          70 PM,
                          Trying to understand what's going on.
                          Are you running the table continuous?
                          If so, why?
                          John
                          804-240-4982
                            I would suggest there is two things here.I have installed over 100 xli and conversions.if the sensor fails the chassis will say table error.if there is another problem, it will say something else.When it blacks out ,please advise what the chassis says.If the brake is hot, then the area to look is here.if things start to run slow first then check the led is not failing thro black friction dust occluding the lamp.
                            any more info would help.
                            Maister
