AMF kickback weight
  • AMF kickback weight
    Anybody know the approx weight of AMF 82-70 wood kickbacks.I have to transport some and need to know how heavy duty of a trailer I'll need. Thanks [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
    I'm sure I can make it fit!!
    Re: AMF kickback weight
    how many you transporting? i couldnt tell you how heavy they are but they are heavy. we transpoted some last year and just used a normal box trailer but that was only 6 kickbacks
      I would guess about 80 lbs.
      John
      804-240-4982
        Heavy.
          The old ones actally have a void in them where the newer style are solid, were they all that way John as I know the ones on my A2's have voids?
          Drill
          David Bolt
          Champaign, IL
          USBC Silver Coach
          IBPSIA BOD
          IBPSIA Advanced
          Technical Certified
          Pro Shops
            If your talking just the wood kickbacks. I just weighed a brand new right hand kickback. It weigh's in at almost 20 pounds. If your talking the entire kickback metak frame and all. That weighs in at 70 pounds. According to my computerized scale.
              Thanks to all for the info. I am probably (maybe)( could be) relocating 24 of them to a new center We are building near Delphi, In. You guys are the best
                The original wood kickbacks are not solid, they are assembled from many pieces of lumber, they do have airspace inside of them.
                The newer laminated kickbacks are solid and much heavier.
                Old school....metal kickbacks? the only metal ones I've seen are Brunswick armor plate and GSX.
                Hey but I learn something new every day.
                John
                804-240-4982
                  John I was talking about the metal tubing And angle brackets,That hold the wood plank.
                    Hey John, just out of curiosity?? any idea what the laminated kickbacks weigh?(ballpark?) These are supposed to be about 5-6 years old. Thanks, Scott
                      Old school, gotcha.
                      Scott, my guess is about 100lbs, never picked one up, picked up plenty of the older ones.
                      John
                      804-240-4982
                        To all, Thanks for the replies..ending up having them shipped. didn't have room on the trailer anyway..Scott
