Bin Straps _ AMF Shuttles
  • Bin Straps _ AMF Shuttles
    Okay I was thinking Normal is the 5, 7, 8, 9 & 10pins... Which I use.
    Now, What Locations do you'll use and why did you choose to Place them there?
    The Old Head Mechanic here used all Pin Locations and I Personally Don’t see why?
    Re: Bin Straps _ AMF Shuttles
    everywhere but the head pin. adds strength to the assembly, helps to keep the shuttle from widening at all bins. doesn't hurt anything.
      Not necessary to have them on every pin, but as mentioned, it dont hurt. the only down side I can see is more possibilities for straps to break. This is a possible pin nicking issue, so there are more to change, and more often. Smaller centers probably wont even notice a difference in extra work.
        I put them on the:
        Two, four, six, eight,
        To show them I appreciate!
        Sorry... friends shouldn't let friends drink and post. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
          Try the Stahls bin strap. It will never break.
          Wang
            <font size="2" face="Verdana, Helvetica, sans-serif">I also use those pin locations as well.
              Wang
              <font size="2" face="Verdana, Helvetica, sans-serif">Do not use the Stahl's bin strap.
              There is not enough room between the shuttle and cup on many machines.
              Use 2 bin straps on the 7 and 10. Use 1 on all others but the #1 pin.
                Originally posted by The Lone Ranger:
                I put them on the:
                <font size="2" face="Verdana, Helvetica, sans-serif">[img]/content/btubb/images/%%GRAEMLIN_URL%%/rotflol.gif[/img]
                  Originally posted by 82/30 king:
                  </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WangJ:
                  Wang
                  </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree with Jerry
                    not a fan of the thick straps either. Had too many instances where longer bolts had to be used, and they chewed the hel out of the pincups.
                      Use the Stahl's Tuffy straps on your 7 and 10 pin holders. Use the thin metal ones on your 4-5-6 pin areas. Don't put one on the 9 pin slot. When you are done use a tape measure from the left corner front to the right corner back--right corner front to the left corner back. Make sure the distances are equal--this will assure the assembly is square!!! Don't mix the AMF pin holders with the Stahl's metal ones, you'll have no problems doing it this way.
                      For Sale- Pickled Eggs--10 cents each, 2 for a quarter, I'll have a quarters worth please.
                        <font size="2" face="Verdana, Helvetica, sans-serif">I'm curious why not the 9 bin?
                          Table head We don't use the one in the 9 pin spot because the 9 bin switch already pushes the pin a little forward and it is not needed to keep the pin in the bin.
                            5, 7 ,8 , 9, 10 is all that are required.
                            maister
                              Well said Lafarge--I've also experienced pins not shuttling @ the 9 pin slot with AMF brown or rubber pin holders--causing a lot of pin jams at the #9. The switch pushes the pins forward and catches on the holders or the strap.
                              Ball Returns Shorted Out?
                              Trip rocker arm
                              Lower ball cushion board
                              Backend motor plug
                              82/70 combi motors
