table run after cycle
  • table run after cycle
    Ive got a machine thats cycles fine, goes to home, then table initiates again after a few seconds and causes sweep run again and interlock.
    SS chassis, not the chassis
    looks like someone switched a motor and caps
    also was told one of the sweep cam switches were changed
    Re: table run after cycle
    think i got it just cam levers out of adj
    still dont know what was done before i got here though
      now however i found one of the chassis i tried on that lane, sounds like the thermal overload keeps on clicking
        <font size="2" face="Verdana, Helvetica, sans-serif">Sounds like the thermal overload in the chassis. There is usally some hunk of metal that is contacting the heatsink under the T1 transformer or the T1 is sagging down touching the heatsink inself. Try to locate where the sound is coming from.
          There is a thermal overload in the MP chassis. Little black gizmo that bolts directly to the side of the chassis....looks like a klixon without a button. (it is self reseting) I have had them constantly reset before, and I think it turned out to be a bad transformer, but was so long ago, I cant remember what I discovered.
            You might have squished some mask plug pins while swapping chassis and shorted one of the mask lights.
            Andrew.
              hey guys im havin a small problem (and by small i mean im starting to pull my hair out) ive got amf 82-70s with solid state chassis and i cant get a machine to cycle ive tried changing boards changing chassis playing with cams ive changed relays iv changed the cycle switch and still nothing just wonderinf if you guys had any idea and if you could hep me from going bald thanx
                  Batman
                  More than likely your machine is stuck in instructomat format. Disconnet the grey wire on the T2 transformer and tape it off. If you're machine cycles now, it was stuck in instructomat.
                  Wang
                    Zactly where I was going to suggest starting Wang.
                    If it stays in the machine, then the instroctomat is the 1st place to start. If that dosent work, can you run the sweep with either the cam or the contactor??
                      hey sorry guys i just got told by another tech that we swapped chassis over and it cycles and does everything it shuld be doing with another chassie but the problem will move with the chassie just wondering if anyone new wat to do ive changed boards relays and cycle button but no cycle even played with cams any suggestions
                        DO you have the orignal 5 boards? or a conversion of some sort?
                          theres 5 boards in there now but have tried omega board in there and still the same
                            checked the fuse?
                            Qualified to do anything with nothing!
                              yea done that but still no go
