Hi guys,
Just had a Unit Compliance Inspection, got wrote up for not having a Lock Out / Tag Out program on my 82-70s. Team wanted a box to lockup the main power plug, preventing someone from turning the machine on. [img]/content/btubb/images/%%GRAEMLIN_URL%%/burningmad.gif[/img] Anybody else doing this?
Cheers,
Steve
remember OSHA, along with alot of other regimes just wanna make everything illegal so anytime they want, they can come get some money. Unfortunately it is a reg, as to whether or not anyone actually does it, (other than having one to show the pencil neck) my internet connection is breaking up
Yeah, we do it everytime a machine needs to be "down" for a repair. BPF's don't rate a lock-out box. We have a lock-out box hung on every machine and we have to use them. It's called C. Y. A.. They didn't ask us if we liked the idea, we just have to do it. If you get slightly injured and need medical treatment, someone is going to ask why you didn't lock-out the mach.. They could terminate you. C.Y.A.
Rep. Rob Bishop (R-UT)
Ball return on 28 you say? Sure thing. Lemme just climb up on top of the machine, unplug the machine, put the lock out box around the plug. put the lock through and secure it, then climb back down to clear the pin blocking the ball, then climb back up, get my keys out, unlock the lock, remove the lockout box from the plug, and plug the machine back in. A 5 second remedy turns into a 2 minute endeavor. The customers would love that.
amfpinboy,
Would you have a grainger part number or the like so I can push it up the chain for $$$.
When you work for the government, CYA is huge. But, it does not make me like it. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Cheers anyway,
Steve
Steve, We have the UCI coming very soon and you better believe that I've got my LOTO in order...We just had our annual saftey inspection and LOTO is what they looked at the hardest...I lock out every time I have a major repair,even for pile-ups and ball returns.j/k [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
BG, Minor calls don't require a lock-out box, but the mach. should be shut off to do a lot of small stuff. I use a lock box adaptor plug for the lock-out box. When you're doing a carpet job you can plug for the pit light. The mach's. on either side need to be locked-out when you're doing a pit. I don't like useing the boxes, but that's S.O.P. now. Ya get used to it.
Originally posted by BG: Ball return on 28 you say? Sure thing. Lemme just climb up on top of the machine, unplug the machine, put the lock out box around the plug. put the lock through and secure it, then climb back down to clear the pin blocking the ball, then climb back up, get my keys out, unlock the lock, remove the lockout box from the plug, and plug the machine back in. A 5 second remedy turns into a 2 minute endeavor. The customers would love that.
<font size="2" face="Verdana, Helvetica, sans-serif">Too true. I have a LOTO station right outside my shop. When OSHA pussheads come around to hassle me, with their "Do you have lockout/tagout protocols in place?", I just point to it and go about my business. But they always find something to whine about.
About 10 year's ago I went to work for a guy who leased a center.
When I showed up the first day, he instructed me to boot the mechanic whom I was replacing, needless to say he didn't take it too well.
About a 3 weeks later OSHA shows up and writes us up for the follwing.
1. The B.E. motor's were wired directly
2. CWC's were left open
3. AM&C boxes were open
4. Lane machine power cord showing wear
5. Chassis covers missing
6. Ball lift guards missing
7. No lock out proceedure
8. The soda vending machine power cord frayed
And a bunch of odd ball thing's which was all caused except 1 item by the mechanic I booted.
It all amounted to nearly $15,000 in fines, Which we were able to get reduced because of the new ownership and correct all the problems.
yes it is bs iam at barksdale afb base and we got wrote up for the same exact thing but the deal is last year when we had a uci the inspector told me that i didnt need a flippin lockouttagout those fluckers need to make up their mind!!!!!GRRRRRRRRRRRR
This is a TRUE story of some of the craziness exhibited by compliance officers:
A factory had a power switch located up on a gantry that required climbing a set of steps and walking across a platform to shut it off... Turning it off in a hurry was not an option unless someone was standing on the catwalk by the switch. This was not acceptable, so an acceptable option was to install a $900 remotely-operated contactor with an 'off' switch at the ground level... which still required climbing the gantry to turn it back on.
The suggestion was made to attach a piece of nonconductive nylon rope to the switch handle, so it could be pulled from the ground level to turn it off, after which it could be reset later by going up the catwalk to switch it back on (just like the contactor).
The suggestion was nixed by the safety officer, because "The rope could inadvertently be pushed upward, turning the switch on."
That makes good (non)sense, doesn't it?
Originally posted by JimDorsin: LOTO is a replacment for common sence. 18 years, and I have never had to use a pad lock to keep my head attached.
<font size="2" face="Verdana, Helvetica, sans-serif">Paul, you might have common sence, but a fellow emloyee might not. Look at it this way, what if you were working on a pit or underneath a table and you have the machine unplugged and power switch off and somebody comes walking by and see's the power off and that it's unplugged but they don't see YOU and end up powering up the machine with you in it...I can say this from experience...When I was the Head Tech at my sons' grandfathers center (GS-10) I was in the pit doing some work, the owner (my sons grandfather) came through the front doors saw the sweep down at guard on a machine, he comes to the back to see what's up and doesn't see me working in the pit and powered the machine back up and hit the reset with me in there. [img]/content/btubb/images/%%GRAEMLIN_URL%%/burningmad.gif[/img] I screamed "turn it off" just as I started to take a ride on a T-Band and he shut it back down...I was pissed and came flying out of the machine asking what the fuk he thought he was doing, he said that he thought I had been cleaning the machine and forgot to turn it back on since he didn't see me anywhere in the shop or around the center...He is one of those owners that dosen't like to see a machine down for too long...He never touched a machine again while I was still working there.
