82/70 xli
  • 82/70 xli
    does anyone have these machines and what is your imput compared to to older 82/70 thanx guys for any imput multi-task
    Re: 82/70 xli
    I believe Drill has them.
      Re: 82/70 xli
      I gots 1 pair!!! Dont really have that much problems with them so far!
        Re: 82/70 xli
        i have upgraded several 70's to xli the jury is still out.
        maister
          Re: 82/70 xli
          AMF had some problems with motor brake noise and failure or coasting. Heard this was due to cheaper parts substitution by their supplier; problem rectified.
          If you're upgrading in the center, be sure each machine has BOTH counter balance springs on.
          If purchasing machines from AMF, I'd get rebuilt rather that "factory select/upgraded", which may have inherent mechanical problems since they are not rebuilt or reworked (they're just as-is).
          We're aiming at upgrading ours this summer. AMF is considering a separate back-end portion of the XL/XL-i upgrade, so a center can benefit fron the new back end motors and pinwheel belt tensioners first, then get the chassis & electrical part later.
            Re: 82/70 xli
            Being a Brunswick person this is my first AMF purchase but from what I have seen so far I would not hesitate to go with this setup in my next center at all. Very solid and not one chasis problem since installed, I went with the factory rebuilt.
            As an owner I think it is easier to find mechanics for this machine.
            I would take this machine over the A2 or any GSX
            Drill
            Drill
            David Bolt
            Champaign, IL
            USBC Silver Coach
            IBPSIA BOD
            IBPSIA Advanced
            Technical Certified
            Pro Shops
              Re: 82/70 xli
              Drill
              <font size="2" face="Verdana, Helvetica, sans-serif">Post of the Year
              Wang
                Re: 82/70 xli
                the old A 2 will never be beaten......
                  Re: 82/70 xli
                  <font size="2" face="Verdana, Helvetica, sans-serif">It was the 1st time it killed someone....lol
                    Re: 82/70 xli
                    the old A 2 will never be beaten...... Nothing mashes potatoes like an A-2!
                    <font size="2" face="Verdana, Helvetica, sans-serif">FIXED [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    Ball Returns Shorted Out?
                    Trip rocker arm
                    Lower ball cushion board
                    Backend motor plug
                    82/70 combi motors
