ring tube
  • ring tube
    changed one out in my lane 2. all 4 bearings new as well. now its rubbing the plow and mat. i can't find it. any clues? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    Re: ring tube
    if all the caraage bolts are tight... you may need to shim the bearings.... just put a couple of washers behind the plate for each bolt on the 2 lower rollers... that will pull the whole elevator away from the plows.
      Re: ring tube
      Bent,
      you might have a warped ring tube. Does it rub all the way around or just in places. I've changed out several ring tubes over the years and for the last 10 or 15 years it's been impossible to get a decent ring from AMF or Vantage. Had to take some of them off, lay them on a known flat surface and beat them with a 9# hammer. You can't get them completely flat but you can use them. You also will have trouble with pin distribution from the pinwheel using these rings. Some rings are also oblong or egg shaped and these are hard to get in round [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_curse.gif[/img]
      Before changing a ring out it's always a good policy to check for both of these problems. Save you a lot of headaches. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
        Re: ring tube
        Is the tube AMF or Vantage?
          Re: ring tube
          Take a look at the 4 supports on the ring tube with a steel ruler.. We had one that for some reason didn't seem to fit right. After some hair-pulling, we found that the angles were too long. I dunno if they were cut wrong or just welded too low on the tube, but it would rub on the plows. We cut and rewelded the angles, and it worked fine.
            Re: ring tube
            Im sure you checked,but make sure the plow isnt loose also.just a thought
              Re: ring tube
              I encountered this, had to replace a noisy bearing one day, grabbed one out of the bin, mounted on the plate, tried to install it, turns out it was a bearing for a 30's machine. I'd compare the old bearings with one of the new ones you installed to make sure they are the same.
                Re: ring tube
                Klixon, thats what I was thinking too. The 30s do NOT have a large nut as part of the bearing. If it (they) were placed on top, that would push the bottom of the wheel foward into the plow(s).
                Gene Simmons for president!!!
                  Re: ring tube
                  thanks everyone for the replies! i ended having to shim the lower bearings out. not 30's bearings, plows nice and tight, and it was an AMF tube. kingram... no doubt the tube is slightly bent, they always are i do agree. and gman... 5 of the 7 angles were ok but 2 didn't line up too well. i just egged the holes a bit and tightend the pizz out of the carriage bolts. first 3 tubes i've had to change never had really any problems. just thought i'd check in with the pros! Thanks all!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                    Re: ring tube
                    Kingram,
                    You said that you have had trouble with AMF's and Vantage's rings, which ones do you use?
                      Re: ring tube
                      <font size="2" face="Verdana, Helvetica, sans-serif">It Never occured to me that 30 &amp; 70 Bearings might be different. Can you be more specific (maybe even Pics) of 30 vs 70 rollers, or is the difference so obvious I would notice?
                        Re: ring tube
                        The 70 bearing has about 1/2" sholder on the bearing shaft. The 30 uses a 1/8" washer for the standoff from the mounting bracket.
                          Re: ring tube
                            Re: ring tube
                            Originally posted by Charley Farley:
                            Kingram,
                            <font size="2" face="Verdana, Helvetica, sans-serif">With the 30's tube..
