sweep won't go all the way back
  • sweep won't go all the way back
    I have a lane where the sweep just started stopping at the 456 line, I don't know how to adjust it to get the back row... HELP!!!
    Marc
    Re: sweep won't go all the way back
    Sounds like your SA cam slipped about 45 degrees- What is your sweep doing when it comes back to 2nd guard position and at 0 degees. Check the position of the cams at 0 with a working machine next to you. Mark them all with a white welders pen for future reference. It helps a lot!!!
    For Sale- Pickled Eggs--10 cents each, 2 for a quarter, I'll have a quarters worth please.
      Hi Marc,Are u looking for a mechanical adj. or an electrical adj???
      Dave
        I think this is gonna be a mech adj... even when I hand crank it completes it cycle at the 456 line... also, I was just looking at it and the sweep rocker arm is bouncing around like crazy thru the cycle...
          Sounds like ya could have a broken sweep rocker pillow block, or the rocker itself maybe cracked somewhere and getting ready to go on you. Good luck and let me know what ya find.
          Dave
            That's at least one of the problems... the bolt that holds the sweep rocker pillow block came loose and fell out... once I figure out how to get it back together and put the bolt back in, we'll see if that's the only thing... Thanks guys!!!!
            Marc
              The crank arm may be slipping on the sweep shaft and the keyway and the rod ends may be shot.if it stops at zero and does not bang the frame check your start measurement lengths and try setting it up from scratch.
              Long Rods start at 25 1/2" approx. short rod start at 10 1/4" approx.
              maister
              Ball Returns Shorted Out?
              Trip rocker arm
              Lower ball cushion board
              Backend motor plug
              82/70 combi motors
