XLi backend sidemount gearbox problem...
Ok, have a XLi sidemount backend motor, and the gears will not come out of the gearbox, as the manual says they will...am I missing something, or is there a trick. Is the XLi Motor & Gearbox manual wrong about something? I follow the directions, and get stuck after I complete step #5, which is, Remove the retaining ring and shim, from the pin elevator drive shaft. Step #6 says to remove the pin elevator drive shaft assembly, but its not exactly coming out...Any help is greatly appreciated.Tags: None
Re: XLi backend sidemount gearbox problem...
Hey, why don't you give QubicaAMF guys a call. There are only a few guys here with that equipment and I don't think they have run into this yet. The number is 866-460-7263. Press 1 on the first menu and 3 on the second.Save the environment, eat more beef.
No more Ethanol, save Beer.
One thing i do know is that on a b.e. gearbox, the pin elevator shaft is the toughest to get out... national that is. if there are any similarities, im not suprised.on a national box you just gotta keep working it until the bearing slips out of its housing.Don't mind me, what you read is invisible.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
