ball return motor
  • ball return motor
    any one ever have a problem when the ball return motor was spinning the wrong way. any help with out haven to buy a new one. thanks.
    Re: ball return motor
    Switch the 2 wires on the terminal board in the stator that are not connected to the motor plug.
      Do you mean the back end motor or the ball return on the approach?
        at the approach......
          what are the wires connected to....
            Take off the inspection plate.
            The white, black, and green wires are coming off the plug.
            There should be two other wires.....maybe blue and red......switch those.
              Did this just start happening? If so….
              Let me guess…These are Franklin motors or Vantage C-90 clones. They have been known to start backwards due to a bad centrifugal mechanism/switch. These motors are not equipped with a capacitor which gives the motor an extra boost in the correct direction.
              If your motor does have a capacitor, then the capacitor or centrifugal is defective.
              Triac
                no there is no capacitor. it is the third one to go but never though much of the first two as they were under warranty.
                  thanks king i may have o look in the morning.
                    Elliot,
                    If the motor was working fine and just started doing this, your wiring is correct. Most likely the problem is the centrifugal mechanism or centrifugal switch is defective.
                    Triac
                      I agree with Triac... had this happen before as well, but mine were always in the caps... SInce you say there are none, I would check as Traic suggested.....
                      Unless of course it is a newly instaled motor, them most likly King has it....
                        Triac has hit the nail on the head!
                        We have this same problem,was`nt a problem up untill the warranty ran out!
                        I tried unsuccessfully to get the problem motors to start the right way with the conventional cent switch and cent mech.
                        I now fit solid start switches to the faulty motors with no more problems!
                        If you want some more details on where to purchase the switches etc please send me a private msg,Elliot.
                          As Triac said, the centri-mech is likely faulty. Happens on our s/pik motors too.
                          Although I'm suprised they'd fail not long after warranty period (assuming a period of a couple of years or less).
                          Maybe they are just getting really dusty/dirty. We vac in/under/around our ball returns regularly (inluding around the motor, which tends to fill up with fluff and dust).
                          Instead of replacing the centri-mech, you might be able to service it (just like a BE or Combo motor). Clean it out (blowing it out carefully with an air nozzle works well) and clean the contacts with a pencil eraser. If they are really burnt, then you may have to burnish them with a file (a very very fine file - and very lightly).
                          Andrew.
                            thanks lads i will have a look. dose any one know off hand how much a new motor might cost.
                              let me explain just how the mtr. runs backwards.It is a faulty start circuit in the mtr.The mtr. will run ether way you start it turning when the start winding don't energize.If the mtr. is not over loaded and a ball hits the bottom pulley, it pushes the pulley backwards thus starting the unit turning the wrong way.I know the bottom pulley has a one-way clutch in it,but with the unit not turning it works just the oppisite.
