table problems
  • table problems
    one of ourlanes on the first ball cycle picks up the pins sweeps the deck goes to put the pins down but it pick's them up again [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_curse.gif[/img]
    and it does thsi all the time
    but when i run the machine from the back it does release the pins
    [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] WHAT DO I DO???
    Re: table problems
    Are the respot fingers letting go of the pins? Sounds like a sticky respot cell or linkage to me.
      Re: table problems
      Is the instructomat switch on at the front desk? We have a few machine that flake out when you try to run scoring with the switch on up front.
        Re: table problems
        You could have your pawl adjusted to close to your shifter link.
          Re: table problems
          I would look at your RSC Links, and make sure they are on "properly". (Small portion on the RSC, & Large portion on your wireways) This is so your plastic clips on the RSC's are not hitting the Links. This just happened to one of my customers, he put all of the links on backwards...caused big headaches for a day or two. But, his was the same problem, only happened when someone was bowling on it, not when he was cycling it from the chassis.
            Re: table problems
            <font size="2" face="Verdana, Helvetica, sans-serif">kind of thay open and as the table goes back up thay close so the pins go back up again
              Re: table problems
              There are a lot of things that could cause your problems. How familiar are you with doing a full RSC adjustment?
              The first two areas I would look at are the pawl adjustment and the stop bolt adjustment on the shifter cam link.
              Many times, mechanics will back the stop bolt out to far to insure that the RSC’s close far enough. The problem with this is that the RSC’s will snap when opening and this is not good. Try pushing up and down on the shifter cam and see if you feel a slight snap when opening. If so turn stop bolt down until this becomes smooth.
              Another troubleshooting process for finding a bind is to slow things down by hand cranking the table and look what is going on when problem occurs.
              Triac
                Re: table problems
                What triac said, plus make sure the nylon sliders are on the 7,8,9,10 fingers. If one of the rear pins gets knocked back and dangles off the rear of the deck, the fingers will not open back up.
                  Re: table problems
                  Does the table make a second revolution, and re pick up the pins, or are the respots not letting go? If the table is making a seond pickup, the cams are out of adj. If the table is not releasing the pins, the paw is out of adjustment or there is a bind in the table elsewhere. Maybe a bent pivot stud.
                    Re: table problems
                    I'm guessing it's the pawl adjustment.
                    But if this just started happening then the pawl may not be the problem. Unless the table came loose from the table support legs, or the respot rod jam nuts are loose and the rod is turning on it's own.
                    Look at all the pivot pins for the levers and respot cells. Replace any bent pins.
                    When the respot cells are open, do the open all the way or are they partly closed?
                    You can also disconnect all the linkages and open and close each individual cell. This may show you what cell is bad. This is a good time to check all links for binds.
                    Mike
                    Mike
                      Re: table problems
                      If you have 1 cell (or more) that the gap is too narrow it can also cause all cells to stay closed. (same reason a pin hanging off the back of the deck would) Puts too much pressure on the cell.
                        Re: table problems
                        <font size="2" face="Verdana, Helvetica, sans-serif">well at the end of the 1st ball cycle the table comes down the cells let go of the pins the table starts to go up the the cells colos again taking the pins with it
                          Re: table problems
                          Did you check the springs for the respot lever on the front of the machine. One of them may have broke.
                          Mike
                          Mike
                            Re: table problems
                            Make sure the respot lever is not worn out up where is pivots on the machine (Up be the table motor.)They can get worn out and also bend the bolt that holds it in place. I replace the inner tube and also the sleave bearings (bronze color).I would check all that has been said and then start replacing parts that I described.
                              Re: table problems
                              ok thank you evey 1 ill get the hed macanic to try some of them things
                              (but im having a go first) lol [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
