Sweep stopping too late on the way up
Tech of the Year 2009
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Re: Sweep stopping too late on the way up
The 2 long rods on the side....loosen both jam nuts and shorten the rods.
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- 1982
Do all the sweep adjustments.
In sequence.
Start with the drive rod.
Then the rods we spoke of.
Then the telescopic link rod end for height.
Then the same rod end bracket for height at the 4-5-6 spots on the deck.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
