Has anyone modified their omega boards for cycling from the desk. I set them up and we really like it. Wondering about the wear on the toggles tho. Was also wondering if there is some sort of control system similar to the x-10 home automation that might be used for remote control of the switches.
Switching control
Switching control
Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.Tags: None
Re: Switching control
We never actually had to "modify" them... the Qubica system has a button you can click that will cycle / rerack from the counter terminal.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
