90XLI...Steltronics
MCU says Locked...
MCU says Locked...
When one of my customers tries to put a machine in Bowl mode on the MCU, it says Chassis is Locked. If there is no way around this, is there a way to turn the machine on from the back? Machine comes on through the scoring but only if the chassis is in mechanics mode. They are going to put the MCU in the back, and want to be able to turn the machines on without calling the desk or going to the desk...any ideas? Oh yeah, the scoring is hooked up through the mask switch?
90XLI...SteltronicsTags: None
Re: MCU says Locked...
HI 82
WHEN THE MACHINE IS IN MACHANICS MODE THE MCU IS LOCKED OUT OF THAT LOOP. THE ONLY WAY TO FIX THIS PROBLEM IS TO INSTALL A SCORCE COMMAND UNIT FROM QUBICAAMF TO GET THE MCU TO WORK WITH THE SCORING YOU HAVE.PM ME YOUR NUMBER IF YOU NEED MORE INFO ABOUT THE SCORE COMMAND UNIT.
I don't want them to have to spend more money, nothing should need to be added...but I will try to put the chassis in bowl mode, and then switch it back from the MCU.
ANYTIME YOU HAVE YOUR XLI CHASSIS IN MACHANICS MODE IT WILL LOCK THE MUC OUT AND THE REMOTE FUNCTION FROM CHASSIS TO CHASSIS.THE UNIT IS THE ONLY WAY YOU WILL BE ABLE TO GET AROUND IT..SORRY
STELTRONICS SHOULD HAVE SUPPLIED THE UNIT WITH THE SCORING KNOWING WHAT TYPE OF MACHINES YOU HAVE.GOOD LUCK!!
THERE IS A NEW WAY TO FIX YOUR PROBLEM. FIRST YOU NEED VERSION 16.0 OR 16.1 IN YOUR XLI CHASSIS TO MADE THIS WORK. THEY NOW MANUFACTURE A INTERFACE CABLE THAT WILL CONNECT FROM YOUR CHASSIS TO THE INTERFACE BOX OF STELT. WE USE THIS INTERFACE CABLE ON QUBICA SCORING WITH XLI MACHINES. IT WILL WORK WITH YOUR SCORING,AND WON'T HAVE TOO HAVE YOUR MACHINES MACHANICS MODE.THE CABLE WORKS ON A PAIR OF LANES.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
