82/70 MP Chassis Pinsetter
  • 82/70 MP Chassis Pinsetter
    I have a machine that when you turn off the Pit run switch the machine turns off. The problem just showed up last night. Any suggestions on what to look for??
    To The World You May Be One Person,but To One Person You Might Be The World.
    Re: 82/70 MP Chassis Pinsetter
    Problem move with the MP Chassis or stay with the pinsetter?
    Also, by machine turning off, do you mean completely off (pit and everything) or just the normal manager control off, where the pit still runs for 1 minute.
    Nedd a little more detail and also what you may have/have not done.
      in reply to Kat-Yes I tried another chassis & board, problem stayed. It turns machine completely off,lights and everything,then when you turn switch back on,everything comes back on.
        OK...has anyone played with anything on this machine lately? What's sounds like is happening is somehow the BE relay toggle (pit switch) is controlling the coil for the M relay which turns machine on/off. Which leads me to believe there is some wire(s) misplaced in the wireway or the C2A plug. First let's verify that the 2 wires coming from the pit switch do in fact land in the right place in the C2A plug, whihcn would be C2-313FF and C2-13L. Verify that on the pinsetter and let's go from there.
          You may want to look inside the rear control panel and make sure everything is connected.
            <font size="2" face="Verdana, Helvetica, sans-serif">I pulled the plugs,checked all the wires,everything seems fine. Reconnected every thing and oddley everything seems to be running fine now. Thanks for the help
              You "disturbed" whatever it was that was causing that and eventhough it has gone away, you need to do some investigating to find the real cause of it. This doesn't just happen for no reason, it may not be doing it now, but you can be sure that if you don't find the cause it will most certainly rear it's ugly head again.
                Give the C1 &amp; C2A a good eyeballing. Sounds like a loose pin.
                  Don't ya just love it when problems arise out of no where and ya fiddle with it, get it going and don't have a clue what fixed it..... [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    Yeah, tell me that's not the most irritating thing in the world!
                      <font size="2" face="Verdana, Helvetica, sans-serif">You must have worked at my place [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                      And why has everyone started calling AMF machines Pinsetters?????????????? that would be the other company machines.
                      Be Proud, be loud and say the word together
                      PINSPOTTER
                      If Wile E coyote has enough money to by all that Acme crap why doesnt he buy his dinner?
                        The old dirt man has done some wiring there.
