Cam switch timing - anyone ever actually do this?
  • Cam switch timing - anyone ever actually do this?
    I was just wondering...OK I have no real life...but has anyone ever done a timing chart of cam switches on an 82-70? I mean how long the SA, etc is N.O. or N.C. contacts are open/closed and the time that the machine runs? Been bugging me...maybe an idea here... [img]/content/btubb/images/%%GRAEMLIN_URL%%/143.gif[/img] If anyone has ever been bored enough to do this, please post. Maybe we can compare really well running machines to "so so" machines! [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_nworthy.gif[/img]
    Re: Cam switch timing - anyone ever actually do this?
    Jon, It's been a long cold winter there in Ohio, hasn't it? Not to worry. The ice is melting and you will be able to go fishing very soon.
    Rep. Rob Bishop (R-UT)
      Jon:
      Check out a print on any of the chassis, MP or SS, if I remember correctly there is a drawing of the cam profiles on it.
      AMF DOCTOR
      The doctor makes house calls.
      AMF DOCTOR
        [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] yea, it has been a long winter - makes you think of wird things!
        AMF Doctor - there is a chart with that on it. I was just curious if anyone ever did actual timing. I have a stopwatch...hmmmmm, I ain't bored YET... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
          Dang you TA2, beat me to it!!!
          [img]http://pic16.****************/VOL657/2474429/4897923/149934618.jpg[/img]
            Yep! Thats the one on the chassis schematic. I just wondered if anyone ever actually figured out the timing in seconds. Great job, guys!
              Yeah Chad,but yours looks a lot better.you goin to the beach this weekend??.
                Will try to! Have to go to Maryland for part of it but from the looks of your pics your place is a must-see.
                Jon,
                Depends on 12.1 or 14.5...or 12.1 and 14.5. Or running a 50hz motor on 60hz. Or 60hz on 50hz.
                Hmmmmmm
                  In my anal retentive quest to find 355 degrees exactly for electrical table zero….I needed to know how many revolutions the motor turn’s verses 1 turn (360 degrees) of the output shaft. By inserting a table shaft and putting a level on the key (for a starting point) I counted 146.5 motor revolutions to 1 output shaft (360 degrees) revolution. Mind you, this is a 12.1:1 gearbox and your tests may very. Using a little math I can set the table at TDC and reverse crank the table 2.03 turns to achieve 355 degrees.
                  Now we can use this data plus the data on the motor plate assuming the motor turns 1750 RPM’s @ 60 HZ (although in reality this will usually be 1758-1772 RPM’s) to determine the time each cam switch is on or off.
                  1750 RPM’s = 29.16_ RPS (revs per sec)
                  146.5 revs / 29.16_ revs / 1sec = 5.02 sec / 360 deg
                  Therefore you multiply each degree you want to calculate the time by 0.01395.
                  Example:
                  66 degrees will take 0.9207 seconds and the motor will turn 26.86 revolutions.
                  Although this is not exact due to number of significant numbers calculated and slight error in measurements, it’s as close as your going to get with the measuring equipment and techniques that are available to us.
                  Triac
                    Example:
                    Triac
                    <font size="2" face="Verdana, Helvetica, sans-serif">You are giving me a headache Brain, I mean Brian...You never cease to amaze me.
                      [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] And I was gonna use a stopwatch... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] Very interesting!
                        Jon,
                        One of the reasons I did these calculations, was for a project I was thinking of making awhile back. The project was an override interface for the cam switches. This device would plug into the C2A (machine/pass thru to chassis) and override the switches with electronic timers. The timers would be calibrated according to these calculations using a hacked stopwatch integrated into the circuit. The function of the project is an emergency override due to a defective cam switch.
                        Kenny,
                        Sorry about giving you a headache. For you, I would suggest…..1 mississippi…..2 mississippi …..3 mississippi ….4 mississippi….ect. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                        Triac
                          Great job, Triac! I could see where that would be a handy thing to have! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                            Kenny,
                            Triac
                            <font size="2" face="Verdana, Helvetica, sans-serif">That's the only method I would know how to use. Everytime after we talk I have to go and take some Advil. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
