Xtreme Sweep Makeover
Tags: None
Tech of the Year 2006
- Jun 2000
- 7945
- A, B, Xima, Via, Switch
- Q,A,B, Stel, Switch, XIIX
- N/A
- Wood, synthetic
- 1971
Re: Xtreme Sweep Makeover
Really cool!
What a great idea.
The lane numbers is the best..
SWEET! Nice job Vernie!I really enjoy the Simpsons. My problem is that I am starting to look like Homer. Doh!!!
Awesome!! Very nice work! [img]/content/btubb/images/%%GRAEMLIN_URL%%/143.gif[/img]
Thanks for the compliments.
Here’s a close look at how numbers attach. Click on any pic to enlarge.
Found out that I took more than 1 strip of Velcro to secure them. Reason I chose Velcro was easy to remove numbers for access to bracket bolts.
Cut the glow capping (or anything to fit the space) to 46 inches. Paint stripe or use auto tape to decorate as desired. I used pre drilled hole near center and attached to sweep with screw and cap nut.
Vernie
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
