steltronic and 8290XLi
  • steltronic and 8290XLi
    Hey guys,
    I have a problem with steltronic and my 8290XLi if the score is set on pratice mode the machine wil go to pratice mode without pins. And if I select on the MCU Bowl mode the machine will turn automatic back to Practice without pins. [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_curse.gif[/img]
    Is ther a way to install that on steltronic that the machine will stay on Bowl mode.
    The machine get's his info from the API van steltronic.
    thanx
    Re: steltronic and 8290XLi
    In pinspotter section under control, you should also have the option for 10 pins in practice mode. This will give you a strike cycle with every ball.
      oke thnx is a lot better than no pins practice
