xli brake for motor
  • xli brake for motor
    Is there an aftermarket for this yet, I am burning them up about every 3-4 months and only having 6 of them in my stock is getting old? I have not taken one apart yet to see if it could be modified but I am not too far from it as there has to be a way to make these last longer.
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Re: xli brake for motor
    there is no way to make them last longer as its a design flaw using aluminum inside harder metals it will always strip out. Once I get one taken apart I will tell you if we can make a peice for the inside.
      i am the same they do not last very long and the sweep goes more so than the table. i have had it open could not seem to do much but when u do open its very strange to put back right.
        The black ones seem to last longer but need regular blowing out the dust or the encoder does not read zero.
        maister
          There may be other issues but our biggest problem with brake failure is the small set screws backing out of the hubs and sitting inside grinding away at disc and hubs.Look closely as it is usually evident by a missing set screw
          Sorry,I can't fix stupid
            ours are striping out the brake pad the alum inside the brake is the problem.
