XLI upgrade
  • XLI upgrade
    We XLI upgrade in a couple of weeks. Does anyone know of anything that I need to be looking for or what problems they have had? Please let me know. [img]/content/btubb/images/%%GRAEMLIN_URL%%/143.gif[/img]
    Fixing things right the first time takes less time in the long run...........
    Re: XLI upgrade
    the motor brakes if they are replacing your motors which they should. the brakes last about 5-6 months then they are striped out because the company that made them knows there is a flaw and are working to fix it.
      Re: XLI upgrade
      What kind of motors are they running on the XLI's?
        Re: XLI upgrade
        82 90 XLI has new motor design .tha machine work similar to 82 90xl the diferent is the keyboard on chasis some funtion you can change from chasis or fromMCU here is the some litle problem ,some mecanics change the settings in chasis and the machine not work good my recomendation need make one list w/ settings and save it
        the motor has new system brake it has many scraper and dirty,need clean w/blow one time each week
        mecanism don have problem is AMF
        jesus
          Re: XLI upgrade
          Motor brake issues,dist belt lacing issue,occasional self activating e-stop switches and dist dr shaft u-joint may come apart.The lacing issue I believe has been resolved and switches activating are rare.Overall great machine .You will love it
          Sorry,I can't fix stupid
            Re: XLI upgrade
            Biggest issue here I've seen is having to reset the camera when scoring stops (and it's still happening way too frequently). [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] Oddly, the second most issue for me is having the the balls come off the motor side of the distibutor drive shaft. I've had that happen three times.
              Re: XLI upgrade
              SATANIC MECHANIC COULD YOU EXPLAIN THESE PROBLEMS YOU HAVE HAD A BIT MORE,
                Re: XLI upgrade
                We're having some kind of real minor electrical issue, and sometimes a pair of lanes will stop scoring. Cycling power to the camera cures it.
                  Re: XLI upgrade
                  IS THE SCORING SYSTEM ON ITS ON ANTY SERGE
                    Re: XLI upgrade
                    Is the camera grounded? If not just run a wire from the camera to the machine ground. Cured our problems after installing PVC capping. Had about 10 scoring stops a day, have not had one since.
                    Mike
                    Mike
                      Re: XLI upgrade
                      Not sure, I'll check Friday. I think I may have mentioned it...(?)
                      MCSS - Longmont? I have a few internet friends from there. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                        Re: XLI upgrade
                        Plastic capping + plastic balls + plastic u/ground track runner = STATIC.
                        Still getting camera shutdowns with Boss & Accucam 3000 until we noticed the paint was not removed from where the ground wire was attached. Much better now.
