weird problem
  • weird problem
    82-70 XLI Upgrades Boss Scoring.4 o'clock sunday every lane quit scoring. Reset front desk comps,reset every cpu in the back.23/24 work fine.Every other lane when turned on,the monitor comes up but the machine won't turn on. I can turn each machine on manually from back or from MCU. If I turn on Lane manually and check in for monitors it won't score.My head mechanic is out of town and not returning messages so I am in charge.We're closed tommorow, I guess the question is where do I start front desk,cpu,logic chassis,scoring cables,amf tech.one last thing computer says communication to every lane is fine. All help would be greatly appreciated.
    Re: weird problem
    when you turn the machine on through a ball and see if you get interlock on the chassis
      Re: weird problem
      Machines work fine, problem I'm having is getting the machines to turn on by the front desk. I'm pretty convinced it's a front desk computer problem that I'm going to have to hash out with tech support.
        Re: weird problem
        CHECK THAT THE SETTING ON YOUR CHASSIS IS SET FOR SCORING NOT CAMERA OR CAMERA NOT SRORING.CANT THINK WHICH WAY AS NOT IN WORK.MAKE SURE IT IS NOT IN PRACTICE WITHOUT PINS AND CHECK THE SETTING ON THE BOWLERS TERMINAL BOARD IS RIGTH ALSO.
          Re: weird problem
          You hit the nail on the head Elliot, reset pin data to scoring rebooted camera,chassis and cpu and all the machines came back,thanks Elliot
            Re: weird problem
            no prob.........but if you want to know why it happened i would guess someone was playing around with the m c u.
