help fast
  • help fast
    I can not get my BE nat. motor to run! I have the orange cans on them one is brand new and is wired correctly. It just sitts there and hums. if I turn the adjustment screw all the way in it will somtimes move slowly and still hum but no full pickup speed.
    Re: help fast
    Try changing the capacitor.
    Triac
      Re: help fast
      If you are in a real hurry; pull the motor cord in a wall contactor add pull the ball- lift belt to start the motor..
      So it goes.
        Re: help fast
        Does the motor do this with no load on it?
          Re: help fast
          Good call Kat!!
          Forgot about a possible sticking carpet or ball lift.
          So it goes.
            Re: help fast
            Where is this magical adjustment screw I keep hearing about? Do you have a part number or Item number from page 12 "Combination Gear motor" diagram?
            Well we're safe for now. Thank God we're in a Bowling Center.
              Re: help fast
              Yes it doesn't run with no load, I just have it sitting on the bench with an adapter cord pluged into it.
              "magical adjustment screw": Is on the SSS lewis orange can used for differant horsepower ratings. I heard they work good with the backends
                Re: help fast
                double post
                  Re: help fast
                  arrgh, can't get the edit button right just disregaurd these last two posts.
                    Re: help fast
                    Thanks for the screw information I have been looking for that screw but only have Quality SSS that do not work and 1 orange canister that has not caused any problems yet.
                      Re: help fast
                      <font size="2" face="Verdana, Helvetica, sans-serif">what are the wire connections for the quality ss? I have those type on all my combos, and none on the back ends. would like the info if someone gets a chance.
