balls jumping off downshute
  • balls jumping off downshute
    hey all its me again. i am having a problem with amf 82-70 with pbl conversion. Only 6 pound balls jump off the down shute it happens about every 10th time someone throws a 6 pounder. i checked downshute both the wooden and the metal to see if there are any breaks or alot of movement. nothing to my amazement everything looks like it is well lined up i just dont get it. usually when i have this type of problem it is every ball weight. please i am confused any suggestions appreciated. leave a post here or if you want to talk to me personally i have a cell phone on me down back call me 1-570-527-8926. thanks i will check here often and let you guys know what the solution was when i find it. thanks Matt.
    When in doubt check at bowl-tech
    When people are around no cursing and throwing things
    Re: balls jumping off downshute
    i had this problem a while a go and found it was the PLB running too fast causing the lighter balls to jump when they got to the top of the ball lift rails. i think it has something to do with the size or type of the backend belt pulleys.
    "Smokey, this is not 'Nam. This is bowling. There are rules."
      Did you flip the ball lift shock to the even lane side of the lift?
      If the shock is on the odd lane side the lift will not pivot high enough and it will "spit" out the light balls.
        After checking the obvious (no welds broken on the upper downsweep track), ensure you are using the 5" PBL clutch pulleys. The 5" is the slowest speed and will not launch the lighter balls from the top of the lift. 4" is medium speed and the 3" is the fastest (not recommended).
          the ball lift is not running any faster than any other lane the shock i put on both sides the ball is not leaving the track til after the ball lift no longer has any control over it it leaves pretty much at the top as it starts to head down the down sweeep
            OK then, are ball wipes in use? Is the upper track level from side to side?
              If you manually lift on the ball lift and it comes screaming down the shock may be bad, your tension is set way to tight or both.
              If your tension is the turnbuckle and chain type…try adjusting it with slight slack when the ball lift is at rest.
              Triac
                  Slowing down my lifts have really elimated the balls jumping off problem at my place.
                  You may want to check to see if your downsweep is level.
                    Be sure that you have the proper tension on your ball lift belt.
                    If you do not have enough tension on the belt it will give way rather than the lift raising. When the belt gives way the ball will be farther under the upper pulley when it reaches the top and this will also cause the Ball Lift to "launch" the ball.
                      One more "goodie" ya may wanna try.
                      Swap out 'factory' three and a quarter inch carpet drive pulley off back end motor with slightly smaller pulley from Grainger.3x771 I believe...
                      fatty
                        Look for damage around the capping 'toilet seat' where the rails enter the underground. if the downsweep track or the transition shifted too far left or right, the balls can wobble enough to contact the edge of the capping and bounce off, causing them to jump off the tracks. The ball damage is usualy pretty easy to spot... it looks like someone took a ballpeen hammer to the edge of the board.
                        You can also check this by laying on the lane at the downsweep, and running the other lane in the pair with only th pit running. Have someone up front roll balls down the gutter so the machine will return them. As the balls come down the rails and go underground, listen for a click or clunk when the ball reaches the capping.
                          It may also be a centering on the track issue.
                          At the top of the PLB the track can be adjusted left and right, also on the lower section of the down sweep next to the lower wiper support.
                          It could be that the track is not quite centred and the ball is clipping off the frame of the the machine causing it to "de-rail", especially if it is coming off before going underground.
                          The track may look centred, but take measurements and re-align it. Place the ball by hand and run it down the track to see if any intereference occurs. It could be catching on the lower wiper too?? Especially if you have had the up-rails out recently.
                          Perhaps try adding a spring onto the side of the PBL to the machine frame to help the return piston??
                          I have lanes which run very fast PBL's and the LBS travels quickly also, due to smaller pulleys being used, and have not come across this as an issue of forcing balls off track at the top of the PBL, in my experiance so far. But hey.... don't over look anything.
