Have one machine which was having issues with. When measuring from the back of the 7 and 10 spots to the back of the table, one side of the table was pulled as far back as possible. This would only achieve 8 inches, the other side was pushed forward to also achieve 8 inches.
This indicated to me that the front of the machine was not positioned correctly on the channels on top of the kick backs.
I know that I should try and achieve 5/8ths of an inch from the 7/10 line to the centre of the bolt on one side, and 3 1/4 inches on the other side.
(This will allow room for the table to be pulled back to 8 1/4 to 8 1/2 inches from rear of spot to rear of table)
Obtain 6 1/2 inches from 7 /10 line to the edge of the pit, with a 1/4 inch gap between the pit and the kickback.
What is the best method of achieving this?? It is very difficult to measure from the 7/10 line scribed on the machine frame to the centre of the bolt that holds the machine down onto the channel on the kickback.
Haven't ever read of any tips here on bowl tech about this.
Any top tips??
PS. Also I must correct a mistake I wrote a while ago. An old 70 machine frame height must sit 19 and 1/4 inches of the pin deck. A new 90 must sit at 18 and 7/8 th's.
