table drive yoke
  • table drive yoke
    I was wondering how to pull the bearings out of the table drive yoke rod end? It is the one that has the double bearing are the snap ring in the middle. Any tips and tricks to get em' out?
    Re: table drive yoke
      just stick a punch in through one side and tap it out by hitting the inner race.
        <font size="2" face="Verdana, Helvetica, sans-serif">ditto. hammer, punch and a vise. There is a retaining ring in the center, so you have to tap each bearing from inside to out.
          Indeed. I've changed many, do it as said and they will come out without much trouble at all [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
            There is also a spacer that fits between the bearings. 000-021-878
              Thanks all that did the trick!
