carpets stalling
carpets stalling
Anybody having problems with carpets stalling.I have a few and they have been in for less than a year.Can you guess which brand?Tags: None
Member
- Aug 2003
- 567
- 82-30,82-70
- AccuScore Plus,Bes X
- HVO Summit,Kustodian Ion,
- HPL Alliance 9000,Anvilan
- 1999
Re: carpets stalling
Let me guess, AMF Pumpkin? Carpets stalling can be a few things but I would first look at the tracking. You want to see at least a tiny bit of space each turn of the front roller between the carpet and the rim of the front roller at least for a split second. If you have the carpet firmly against and can't see a little gap at all, your tracking too hard and that can cause stalls and quick wear. Other thing is front roller tension and that being that the roller hinges are not stiff and that the springs aren't weak. My other thought which I hope it isn't, is the carpet stiffening up from oil drying it out. If thats the case, thats gonna suck. I think I got all the culprits, did I miss any?
Indexer2
Front roller hitting against the kick-back. Carpet comming unraveled and winding around the roller & bearings. Pin laying in between the carpet. Bounce plate broken or a piece laying against the carpet.Drive pulley not tight on rear shaft.
Roller tension & bearings already covered.
Thats all I can think of off the top of my head indexer2Even a old dog can bury a bone
These are Vantage carpets that are discontinued. Was told I need to replace my support springs,my other carpets are fine.
We thought we'd beat the stalling issue a few years ago by installing fresh springs on our fr.roller hinges.Got about eight lanes in and problem was getting worse!Well,stopped everything,scratched our heads for a bit,then decided to measure some of the new springs in from Vantage against old originals.Newbies were about 3/16" LONGER than oldies!!!Perhaps if they woulda missed 3/16" shorter(wink,wink-hint,hint)
that may've been more gooder me thinks...fatty
Originally posted by James Bandy:
Remove the rear roller and use some 80 grit emory cloth to rough up and remove the glaze on the surface of the roller.
Works wonders!
just buy a good carpet, and you dont have to deal with it. EBN is very reasonably priced, and seem a good carpet... CALL ED!!!!!!!!
I have done the grip tape but,these carpets are less than a year old.I want these replaced. I was told from a rep.they didnt know about this problem.
Amf Platinum carpets. Pricey, but damn good so far. Have like six of them. Been in for...ahwile. Have no concept of linear or exponential time. Six months? A year? Hard to say. They rock though. Right out of the damn box they rock.
Spray or liquid adhesives help, so will scuffing up your roller.
I have cut links off of support springs to help this, but its a b*tch to get the shortened springs back on sometimes.The impossible often has a kind of integrity to it which the merely improbable lacks.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
