Continuous Cycle
  • Continuous Cycle
    I have 82-70's with Solid Statw Chassis. They have the MK-70's with expanders. I had a continuous cycle on one of my lanes and changed the chassis and it fixed the problem. my question is: Is the problem isolated in the MK-70 or the expander board, or should I look somwhere else in the chassis it's self. Thanks for any input!
    Re: Continuous Cycle
    If you believe the MK70 or the expander is at fault, put each of them in a seperate machine with a different chassi to see if the problem follows. Then put the original chassi on another lane to see if it exhibits the same problems.
    Wang
      C-2 should also be checked
        Just a note for ya'll, had a continuous cycle problem a week ago. Tried changing chassis and everything. Turned out to be a program error when lanes were uploaded that morning. Would have saved me 2 hours of frustration if I would have reuploaded first.
        Of All The Things I've Lost....I Miss My Mind The Most.
          The problem was in the Mk-70, at least it was when I swapped boards from another machine.
          Thanks for the help guy,s!!!!!!!!!!!!!!!
