I need some info
  • I need some info
    I need some info on the Solid state chasiss with the Xop board in it. I need to know if there is anything in that board that could cause that machine to inadvertanly cycle on its own. Like maybe a ground that could be off or somthing in the chassis itself. I have had these and never seen what I'm seeing with this scorng attached. the problem that I'm have is in the Qubica scoring section. Still not convinced it is the machine or scoring. Everthing I've tried rules out each other. Just in case I would like to have a diagram Or some solid proof of somthing other than the scoring. If anyone out ther has had some of these boards cycle on there own please speak up. Thanks in advance.
    Re: I need some info
    May not be much but there is another thread on here about someone having similar problems with a c.b. radio and even someone stating they had this same problem with smoke eaters. Could be worth looking into and shutting down a few things just to see if it makes a difference.
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
      Thanks drill I will look into it and see if the smoke eaters might make a diffrence. As far as radios I haven't heard anything come through the P.A. like he did.
        That is something that XOP boards are known to do. I have heard it from a lot of people who have them. I suspect it is problem with the software that they never fixed. I have yet to find a fix that anyone came up with. Ya just gotta live with it or get Omega Teks.
          I had dealt with XOP's for 2 years and never have seen this. Sorry if I can't help here, but a loose reflector on the ball betects is something often overlooked. sorry that that is all I can add. Not to insult your intelligence.
            I have to agree with bent wrench. I've had XOP's in the 5 board chassis' for over 8 years + with no problems that's been described. However I have AccuScore+. I'm sure lafarge has checked the obvious, touchey cycle switches and reset buttons, bare wires in the underground channel, electronic triggering, etc. If all of that checks, I might lean towards a grounding problem.
            Leyton at Tahoe
              I had this years ago in a 16 lanes 70's house. Only the first 12 lanes had this problem. All lanes had SS chassis with Omegatek boards. It only happened mid summer or mid winter. Turned out to be static discharches on the ballreturns. The first 12 lanes had Mendez ballreturns with synthetic balltrays. The other 4 lanes had Brunswick ballreturns with a metal plate in the middle of the balltray and did not have this problem. I made a groundwire in the ballexit of each ballreturn that touches the ball when it comes up to discharge it. No problem since.
              I think that if your machines are cycled by your Qubica scoring (misalignment of photocells or similar), you would have a (zero) score coming up on the monitor of that lane each time it happens.
              If a machine doesn't want to be fixed, it will let you know. Over and over again!
                Looks like this problem was solved and the answer is in the Qubica scoring section under same user name.
                Drill
                David Bolt
                Champaign, IL
                USBC Silver Coach
                IBPSIA BOD
                IBPSIA Advanced
                Technical Certified
                Pro Shops
