GSX setting table lever
  • GSX setting table lever
    Hey, i am having some issues with my setting table lever. It has broken off a few times and i cant see what exactly is happening. Is there a certain adjustment i need to do or could this be a result of some other parts out of adjustment on the table?
    Not sure what you mean by setting table lever. Could you provide a picture or location on the table description, please?
        This part has broken several times over the past few month's.
          Ahh, okay. There are several places that I'd look at.
          Is the J1/EJ switch plate set right -- is the metal foot lever and assembly set wrong or is it binding when it is supposed to move ...
          Do the swing arms on the table pivot freely .... both when ran by machine and rotated manually by hand ....
          Are the swing arm connecting links aligned so there isn't lateral stress ....
          Is the aft swing arm sitting properly in it's mounts ....
          Is (was) the wedge installed on the end of the swing arm where this mounts ...
          Pretty sure there is something binding in one or more of these locations that is causing your problem.
            We had the same issue and we think it was due to the end of a spotting tong tip broke . It would catch the table and bind, then it snaps free and slammed the table closed. We broke 2 in a week until we found the issue with the tong. It was cracked but had not come apart, and it respotted fine no issues there. We also broke a couple of detector plates. But like I said once we repaired the tong have not had any issues. Later Chief
              So the swing arms were catching on tongs not open? Hadn't thought of that - whenever my tongs were stopping the swing arms, it'd stop it completely and blackout...hadn't had any snap loose.
              Good one to add to the list to be checked.
                Thanks for your help. I am going to check all the parts and issues you guys mentioned and hopefully i can get it sorted. I will keep you updated. Thanks again
                • ChristianP
                  GSX table won't rise
                  by ChristianP
                  On a GSX the table won't rise, when it poses the pin the table gets stuck a 1/3 above the pindeck.
                  When rising manual there no there's no problem.
                  Already did...
                  11-21-2010, 05:13 AM
                • dangermouse
                  GS-X table cycling problem
                  by dangermouse
                  Hi all
                  I have a problem with lane 12. It is not cycling properly where the 7 and 10 pin drop in on 1st detect. the 3 and 5 pin drop in on second detect then collect the...
                  04-12-2011, 10:11 AM
                • GSXTexas
                  GS-X table bolts/stud
                  by GSXTexas
                  I have 8 year old GS-X's, with in the past 4 months I have had 3 tables break the bolts/stud on the table. Table levels are check monthly, as well as other PM the machines. Is...
                  10-06-2016, 10:38 AM
                • Dwolf76
                  Crooked table
                  by Dwolf76
                  Had a table loose a c clip off the tower on a gsx . The locking key fell out and now table is coming down crooked. Could it be a couple of links off? Looks level at home until...
                  08-29-2016, 02:22 PM
                • mouse
                  lever problems
                  by mouse
                  I have a 16 lane center nearly a year old and a huge part has been failing. It is called the lever. It holds the table in a horizontal position and the stroke limiter solonoid...
                  10-03-2004, 03:14 AM
                Broken Things!
                Help-broken Part
                Greeting all.
                Thanks for looking.
                Bolton454
                Pin Damage
                Gold Crown Masking Unit
