76 error
  • 76 error
    I have gs x and on the 2and ball table goes down picks pins up sweep the deck like it supposed to then when it goes to set them it puts the pins down and try's to open tongs but it's like it grinds that's when I get 76 error code.
    th ett n 3then I turn the machine off back on it sets the pins no problem.
    When I dealt with this, it was a combination of a couple things. The ST switch was being activated at the wrong time and caused these faults.
    Work I did to deal with it: Tong clutch needed cleaning, which also allowed me to set it to less tension after cleaning. The main tong drive gear on the table needed a new hose washer. This lessened the kickback when tongs opened. I also re-positioned the stop block on the drive rack for the switch. 2021-06-06_13-59-30.png
      I assume what you're talking about is after the 1st ball is delivered. Usually after the 2nd ball is delivered, pins left standing are only detected, not picked up.
      Check all the gearing on the table. God forbid an unwanted object fell in, and is causing some binding with the spotting tong movement.
      Brunswick provides a downloadable manual. Error Code 76 is explained in Section 6: Troubleshooting. Looking at the clutch, as loadtoad mentioned, is one of the possible causes.
