4th mount point for pin deflectors
  • 4th mount point for pin deflectors
    Anyone ever try drilling a hole on the other corner of the pin deflector and bind it to the BA or lane divider?
    You do not have permission to view this gallery.
    This gallery has 1 photos.
    I mounted a small bracket to the cushion stop bolts and bolted the pin feed deflector to it on the BA side.
    let me be myself
      To stop the deflector from catching the back end of the door halo or bolts, I put pieces of carpet tile on the BA box directly. Use carpet tape to help hold them in place and once in a while replace the tape.
        Love both ideas. Our T-Bands are all in bad shape from deflector wonkiness. Almost always from deflectors bending backwards behind divider or BA edge. Using 8mm spacing at lowest spot, but ensuring leading edge cannot allow pin to go below.
