4 pin not setting
  • 4 pin not setting
    My four pin will not set but machine keeps running like it has one in the pin holder but doesn't. I have replaced micro switch then entire pin holder, cpu, then nexgen. I believe it has to be in the wiring but I cannot find a break in wire anywhere. Any suggestions?
    If I can't fix it I'll break it so no one else can fix it either.
    Re: 4 pin not setting
    Try switching table cable with another lane.
    If everything else fails - get a BIGGER hammer!!
      Swap the harness out. I had hv and io boards. If you have this try changing it
        have you followed all the connections to make sure they're all secure? i had a few problems on a lane with one of the pins not being released, turned out the cable at the back of the station had a loose wire that just needed pushing in.
        This is not 'Nam. This is bowling. There are rules
          Does it always get a fake signal from the 4 pin? If it is intermittent, it could be the detection paddle on the pin holder. Sometimes the force of the pins falling into the holders will cause the paddle to wiggle, sending a fake signal. This is much more common with the steel paddle, but I guess a plastic one in bad enough shape could also be doing it.
          My abilities are only limited by those who try to test them.
            The best I can tell it's in the wiring somewhere. I've a table wiring harness and will replace all the wires.
              No need to replace the whole loom. Just use a multimeter.. You will soon find the faulty cable.
                Thanx for the input i'll do that.
                  Use continunity settin on multimeter (its got the arrow and the S on its side).
                  Pop out the table molex on the table, and unplug all cups. Pop the test pin in one of the holes in molex plug and test each terminal on every plug. You will soon find the break.
                  I found it easier to take out the table and do this. Doesnt take long. 15 mins.
                  Help-broken Part
                  Greeting all.
                  Thanks for looking.
                  Bolton454
                  Pin Damage
                  Making TDM's adjustable.
                  1:1 shaft wear
