One and a half year old GSX machines. This will be the 5th pivot bearing that has broke. This one decided to take out a few things with it. Snapped the stroke limiter shock stud in half, the rest is fine. Broke one pin gripper on the #4 pinholder. The T-stop did not suffer any damage which was kind of surprising.
So I got all the parts replaced and ran it in diagnostics for 15 minutes everything seemed good. Well I just found out that it's knocking pins over. Not sure if it's spot or respot. I did notice when I was replacing the parts that the chain the runs from the bottom and top of the 10 pin side tube had slack where it mounts to the top of the tube. It's slacking enough that the link that mounts to the tube sits at a 45 degree angle the rest of the links are straight. It's easy to move so there is no tension on it. But there is tension on the bottom of the tube chain link. when the table is down the chain is pretty tight except for the top link. when the table is up the entire chain is sloppy. Much like the rest of the house. The chain I'm referring to is part number 47-075486-004. So I'm not sure what could have happened to the chain to make it sloppy like this.
I can understand the stoke limiter shock breaking, but I'm having a hard time figuring out what broke the pin gripper. In a downward movement the gripper should have been pushed upward.
I guess it crashed pretty hard as it made a lot of noise.
Does anyone know of a stronger version of the pivot bearing. If not I'm thinking of taking a spare pivot bearing to a fabricator to see what they can do. This thing just scares me, it just isn't designed to hold the weight of the table. I tried lifting the table to put 2x4s under it and could not lift it at all. Had to use a pry bar.
Any help would be appriciated.
Mike
Mike
