gsx shark & 10 pin
  • gsx shark & 10 pin
    tues power surge when i went to use it wed a.m . the shark wont switch also the 10 pin holder doesn't think it has a pin in it . swiched holders checked solnoids with ometer swiched board that little one in side on side of negen box could be two differnt things or are they be the same problem any help thank you
    this one is working now
      A had the same problem and then decoveryed it was the transformer assembly that might not be given u full power and that works your shark fin and 10 pincup
      Streamlane Mask Halo Lights
      Baddest Tool Chest In Town
      Adios, motor boater!
      Aluminum Repair and Welding
      http://aluminumrepair.com/...
      Hi, guys.
      check this jam...
      the ball stuck the table up
