Hello everybody, i have a machine that keeps cycling but its in tenpin mode!! same as if it were in diag mode? any idea what can be causing the cycling?
GsX keeps cycling in tenpin Mode...
Hello Danilo
So tenpin never ends its cycle? Could be that sweep falls down and then automaticly starts with new cycle and so on and on.. Try to check lenses on ball detect. Sometimes to whipe them with clean paper tissue is enough. Or maybe you have to adjust ball detect.
Good luck
DI’ve got problem for your solution…
Or - CPU EPROM could have a glitch. Changing the board to another machine will tell.
I'm assuming the normal more doesn't cycle as does tenpin. And you have no error codes in diag..
Thats right.... NO Error codes in diag mode, and in frameworks mode it stops cycling! actually it cycles only in tenpinmode (same as diag mode) . i thought about a shortcut in cables from ball return but nop they are ok. thats on right hand machine, and left hand machine works perfectly. I will try to swap the nexgen with other pair of lanes to see if it drags the error, or remains in the same machine. Thanks a Lot, Guys, its a new installation so i will have to wait for electrician to finish their job to keep testing my equipment.
Thank you very very much Guys!!!
