Hi
we had two HV boards blow, someone from a different site has repaired 1 board by making a good one out of the two.
Now I need to find replacement resistors and transistors, I suppose someone doesn't have any knowledge of what items are on the board, the transistors I can't find any stock in the UK from the same manufactor, I can get the relays from RS so that isn't a problem and the resistors I don't have a clue about.
