not setting 4 pin
  • not setting 4 pin
    4 pin not setting. lane 24...changed the pinholder, repaired some wires, no luck, swapped I/O with lane next to it, 24 worked once,23 now wont set 4....thx any help would definitely help
    Swap the cable to the computer to the table with lane 22. See if the problem moves with the cable.
      Aye what Beerman said.. Swap table to Nexgen cable..if that don't work I would change table wiring harness if u have one in stock..then try to repair the old one if that is the issue. I would think it is in one of these 2 areas since u have changed the pin holder already.
        after changing cpu and io boards around with good working ones now both machines when i cut them on takes a few seconds to power up sweeps drop, tables go down then back up along with sweeps then gives 70 code......i did swap both the hv and lv boxes with 21/22 & the error is definitely in the LV box!..just dont know what is in there making out do this......b4 switching the boxes back to 23&24 turned them on works great except still not setting 4, replaced upper wire hardness not it definitely must be lower one....but i have to get the error code problem fixed 1st........its acting weird fsho......thx for yalls replies though....
          You could have a bad connection at the box, (Do you have consolidated or nexgen) one of the pins could be pushed back or out if you have checked both table harness and cable.
            consolidated......im going to check all the hardness now
              I recently experienced this and it was my pinholder solenoid on two different machines within a week of each other. 70 code might be hv board ceramic fuses.
              If I can't fix it I'll break it so no one else can fix it either.
                we just had this same problem check the harness doesnt have a broken wire in it :0)
                  i have the same problem but on the lane 11 and 12 .I change the solenoids and microswitch on both pinholder 4 on both lanes but nothing happend i change lv board and hv board and wire from nexgen to pintable and nothing happend...
                    That only leaves the table harness and that sucks to replace. Good luck.
                      i cant understand what you mean table harness ,my english is bad im from croatia can you explain me on better way
