Damaged setting table
  • Damaged setting table
    Using the T-band patch
    Device about a year and operating normally
    When the pin hit again, T-band bending, and restitution
    pic
    http://www.facebook.com/media/set/?s...5128512&type=3
    Interesting fix. If I were to do that, I would add another layer of T-band to cover the metal edges of the table. That should also give a bit more strength/stiffness to the repair.
      I invented this method then the network discovered this
      From Brunswick
      settering table repair kit
      http://www.brunswickbowling.com/downloads/support/Installation-Instructions_Setting-Table-Repair-Kit_47-902746-000.pdf
      My predecessor group leader Buy More than ten Medieval settering table
      I don't know why
      I don't like chang settering table , so tired by adjustment
        The setting table repair kit does work very well. I have done all of mine. Problem is: it costs too much for what you get. Should be much cheaper.
        John
