Pins getting roughed up around middle
  • Pins getting roughed up around middle
    I got one lane that just shreds the fat middle section of pin. Help
    If I can't fix it I'll break it so no one else can fix it either.
    Check the pin deflectors at end of smart shark for rough or broken medal. Right after the shark as the pins move to left or right side if the part the pin slides across as it goes to the to the side gets cracked or broken it will maul the pins pretty bad.
      Yep, agree with that.
        Also check pin station guards for damage.
          Also check for missing square caps at the bottom of the sweep wagon and make sure they are not missing.
            Check your distributor shoes as well, (metal frames in front of shark where pins distribute to main belts
            Kegel Certified
            Brunswick GS Certified
