Problem with 7/10 pin not double loading
  • Problem with 7/10 pin not double loading
    We are having an issue with one lane where the 7/10 pin will NOT double load when it returns home from setting a full rack. Any thoughts?
    DO the Grippers open? If they do but the pins don't drop I would check table height or you may be able to lower the foot on the pin release lever. If they don't I would look to the electronics as the problem.
      Check the A and B angles before you go into the electronics.
      "Party on dude!"
        The A and B angles should always be confirmed as part of the table height adjustment along with making sure the table is level.
